Labview 2020 creating header for map datatype
Hi all,
1.I am trying to create c header file for map data type,the output is an empty array is their any method that i can create c header with map datatype with call function node library?
2. while trying to create dll i am getting error (Exported VIs for shared libraries and .NET assemblies cannot include the map data type in their connector panes.)
(1,526 Views)
Accepted by topic author irfa
@irfa wrote:
Hi all,
* void?
That seems to be a clear indication that it's not possible.
Convert the map to two arrays (keys and values) and pass those.
There simply isn't a 1-1 match to LabVIEW maps and C\C++ maps. So passing it just can't be done.
(1,479 Views)
