Showing results forĀ
Search instead forĀ
Did you mean:Ā
Labview 2016 Compact RIO on Windows 10
I am trying to test Labview 2016 Compact RIO on Windows 10 64-bit, as the company is moving to Windows 10. To make the test, I run it on a Virtual Machine, as I have 2015 running on Windows 7 and it works.
I managed to install 2016 on the VM, but when I start MAX, it complains for the driver.
When I try to run NICRIO1600 on Windows 10, I have an error message "The specified path does not exist." (See attachment.)
Is there a known problem on it? What path does it searching for? Any help would be appreciated.
Zoltan
(4,307 Views)
ZoltanMTS wrote:When I try to run NICRIO1600 on Windows 10, I have an error message "The specified path does not exist." (See attachment.)
Which attachment?
I can only state that I have no problems with LabVIEW 2016 & cRIOs and Windows 10 Pro 64-bit.
Regards, Jens
Kudos are welcome...
(4,290 Views)
Hi Jens,
any comments on installing the (full) FPGA module to a Win10 computer?
(4,286 Views)
Accepted by topic author ZoltanMTS
GerdW wrote:any comments on installing the (full) FPGA module to a Win10 computer?
Hi Gerd,
well, installing all components for a local FPGA compiler will still not work on Windows 10. I switched over to the compile cloud server of NI.
Regards, Jens
(4,284 Views)
Thanks, I was after this information.
Zoltan
(4,261 Views)
Is it possible to know what is NI's plan to make cRIO Windows 10 compatible?
Thanks, Zoltan
(4,250 Views)
IMHO cRIO is Windows 10 compatible. What's not compatible is the complete FPGA compilation tool chain. Someone from NI has to answer if and when that will be the case again. It's a mystery to me why the ISE 14.7 support could be installed for LabVIEW 2015 (after a warning) and not anymore in LabVIEW 2016.
Regards, Jens
(4,219 Views)
