Labview 2010 with Embedded ARM
After designing a Analog to Digital circuit and pressing RUN results in a compilation error L6050U, and the process terminates. What is causing this problem? All the computer in the lab are showing the same error.
(2,548 Views)
Hello calijoy,
My name is Lisa, and I'm with National Instruments' applications engineering department.  We typically see this error when our customers are running an evaluation version of the compiler, so please make sure you've registered the software for all your lab computers. Otherwise, can you run a shipping example to see if the same error occurs? You can find them by going to Help >> Find Examples... Then navigate to Toolkits and Modules, ARM, and run a VI under "Fundamentals" for your controller.
Can you please also check to make sure that your device is supported?
Thanks for the question and have a great weekend!
Lisa
(2,516 Views)
