02-09-2026 09:29 AM
Hi
There is a tutorial for using LabView with Raspberry Pi in NI web site:
Getting Started with Raspberry Pi and LabVIEW Community Edition
Is it really working with Raspberry Pi and Raspian OS?
I installed LabView into Raspberry Pi/Raspian but there was an error; ARM is not supported..
Should I change Raspian OS to Ubuntu?
BR, Ilkka
02-09-2026 12:02 PM - edited 02-09-2026 12:03 PM
As far as I understand, you develop the application on your Windows PC and set up the Raspberry Pi as a target for your built application. You don't install LabVIEW on the Pi as you would your PC. You can follow the directions on the page you linked, in particular these ones. Step 1 refers to launching LabVIEW on the Windows PC.
02-09-2026 12:07 PM
How closely did you follow the linked instructions? You install the community edition on your PC, not on the Pi. It will communicate with the PI via the linx toolkit.
02-09-2026 01:05 PM
Thanks a lot..
02-09-2026 01:07 PM
I just read the title and based on that I tried to install LabView on the Raspberry Pi.. But this is clear now.. Thanks a lot.
