LabView and PCI6035
Hi all
Is it possible to generate with LabView and PCI-6035E a triangle
waveform with frequency 20 Hz at 500 points at each waveform using AO
Update Channel One Point and read the response for this points with AI
Sample Channel One Point ?
Thanks for each tip
Robert
(2,783 Views)
Both AO and AI VIs that you mentioned are software timed VI meaning you are not performing the operation based on the hardware clock (not very accurate timing). You should use hardware timed VI e.g "function generator" example in labview and "Cont Acq and Graph Buffered.vi" example in labview. Another good thing is that those examples perform buffered operation which involves downloading/fetching the data to/from buffer and then start operation on the board.
A Rafiq
(2,783 Views)
