LabView VI in text format
Is there a way to visualize a VI in ASCII text?
Message 1 of 22
(9,319 Views)
Nope (at least not yet).
You/someone else could write your own description/pseudo code, but there is no quick way to just open it up and see it as text.
Message 2 of 22
(9,317 Views)
You mean something like this:
.DDDDDDDDDDDDD  .            .
.Z............ ............................... .... .... ...
 Z,=.~7Z=..$:.  ..       .   .          ....................
 ZZZZZZZZZZ...ZZZZZMMMMMMMMMMMMMMMMMMMMMM...................
 Z..Z.,8~~~...ZZ,Z..                    M ..      .      ..
 Z..Z.,ZI~~...ZZ.Z..        .           M...   .  .      ..
 ZZZZZZZZZZ...ZZZZZ.   .              . M...................
         .  . .... .   .         .    . M.......,........ ..
 . .    ..  ...... .   .                M.......D8$:,:.7. ..
              .... .   .::=M  . . ..    M.......NMMMMMMNM,..
             ..... . ..,NN,MM  .  .  . I:,......:++?I+I.....
         .    .... .  .,M,,M,.         +,,......:7+I7?7.....
       ...    .... .    MM,MM.     .    M.......II7IIIIIII..
 .      ..  ...... .    .... .          M...................
        ..  .....OZZZZ..                M...................
        ... .....Z.:.,..................M...................
            .....Z.~.,..                M...................
        ... .....8ZZZZ................ . ...................
        ..  ..                        M ....................
        ..  ...DDDDDDDDDDDDDDDDDDDDDDDDDDD..................
                                             GlassGiant.com
(A for-loop to generate an array of random numbers in glorious ASCII art).
You did say "visualize in ASCII text".
Message 3 of 22
(9,312 Views)
Absolutely! It is actually very easy to do.
Create a VI and save it to disk. Change the file extension from ".vi" to ".txt". (You might have to adjust your settings to show file extensions for known file types)
You will get the following warning.
Click on 'Yes'. Now you can double click on the file and open it up in Notepad in order to visualize the file in it's ASCII representation.
As you can see the VI simply gets saved to some programming language called Perl.
LabVIEW 2012
Message 4 of 22
(9,302 Views)
.DDDDDDDDDDDDD  .            .
                                             GlassGiant.com
Watch out for the performance of that VI.  It looks like you have a few coercion dots in there.  Smiley Wink
Message 5 of 22
(9,285 Views)
Darn it, I knew I should have gone for the color ASCII art. That's the bomb!
Message 6 of 22
(9,279 Views)
You could use scripting to generate a text description from a VI, but creating the code wouldn't be simple and I can't imagine why anyone would want to do it.
Message 7 of 22
(9,254 Views)
Tools>Advanced>Export Strings
"Should be" isn't "Is" -Jay
Message 8 of 22
(9,181 Views)
How about the LabVIEW C Code Generator Toolkit? It's ANSI ASCII!
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209015
-AK2DM
Message 9 of 22
(9,168 Views)
I imagine that if I could save a VI as an XML file that contained every detail of every component on the screen (the location of every wire, every corner, every icon, etc., etc.) then I could use the sort of source control that's used by programmers in text-based languages to check in changes, merge changes, etc.
For example, if I go in and make changes to the stuff in a certain case structure, for example, and at the same time another developer goes in and changes stuff in some other part of the VI, the two developers could check in their changes and the merge would happen automatically, just like it does in text-based languages.
Currently the facility for merging changes from two developers altering the same file is so cumbersome, time-consuming, and error-prone that it's just a non-starter.  As it stands now, two developers simply cannot work on the same project at the same time.  The cost of merging changes together is so prohibitive that we must set up a dev environment where it cannot ever happen.
Message 10 of 22
(7,684 Views)
