LabView VI for HP 4145 : diode measurement IV
Accepted by topic author GeorgeRH
Hi George
I can't see what commands you are sending to the HP4145, so here just a few general remarks for that instrument
Make sure your communication is ok. HP4145 likes to have a CR/LF after each message. To test that, send an "ID" command to the instrument, it should answer with the model type and some software revision numbers. As long as this does not work, nothing else will.
When you turn on the HP4145, there are some default setting on which SMU is VAR1 and so on. If you define just SMU1 as VAR1, the other channels will retain their default settings and chances are there is a second channel defined as "VAR1". This will of course result in an error. Define all the other channels as "CONST"
Hope this helps
Good luck
Guenther
Message 11 of 17
(2,542 Views)
Hi Guenther:
Thanks a lot for the feedback. I can confirm that I have communication between the equipment and LabView through the GPIB-USB-B interface: I get the ID of the equipment in the NI MAX and also any change I apply to the" HP4145B Example.vi" is seen then on the equipment itself..
Moreover it seems I have managed to get rid of the error by adding a Time Delay function between the "Send Message" block and" Receive Message" block. As a result I got rid of the "error 6" and now the measured data which appears on the display of the equipment is being transfered to the "Graphics plot.vi" in HP4145N Example.vi. From there I exported the graph using "Copy to clipboard" command and saved this data into a .txt file. Seems it works this way.
And regarding "VAR1" you are perfectly right, SMU3 also takes VAR1. Therefore, I have later disabled all other channels leaving active only SMU1.
Many thanks again for the feedback.
George.
Message 12 of 17
(2,538 Views)
hi George,
hope you're well. I am getting stuck in the same erroer 6 problem with HP4145B as well. Your experience is really helpful! But I am just a little bite confused about the adding Time Deley function bewteen the Send Message and Recieve Message. Could you please give a detailed introduction to this step?
Best,
Cici
Message 13 of 17
(1,708 Views)
This thread is 5 years old but they probably used something like the Time Delay above.  See how it will cause the data flow to wait for one second between the write and read.  Usually this is not required but some hardware needs a small delay.  I usually use 100mSec or so.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 14 of 17
(1,697 Views)
A delay isn't the way to do it.  Set a long timeout (60s), transfer the data, reset the timeout (1s).  I do this with all of my 4155 code and it works without error.
See this Knowledge Base article - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAQKSA4&l=en-CA
Craig
Message 15 of 17
(1,687 Views)
Is it possible to show the VI with the your steps as I am not in to Labview Development but trying to use the available one to get a working Plot output
thanks
kannan
Message 16 of 17
(1,583 Views)
Your question isn't very clear.  But you can start with the LabVIEW 4145 driver from here - http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1765
Study the examples and try things out.  If you run into trouble or can't get things to work post your code (start a new thread, don't piggy back on old thread) with your specific questions.
Good luck,
Craig
Message 17 of 17
(1,556 Views)
