LabView Runtime Engine 7.0 trys to install at start up
This just started happening, every thing was fine a few days ago. Now when I click on the LabVIEW desktop ICON it says it wants to install the 7.0 Runtime Engine. And asks for disk#3  Do I need this?  Eventually after canceling prompts for a few minutes it loads my lab view and my VIs seem to work fine.
I,m using the 8.6 student edition,
Any Ideas?
Alan Martin
Message 1 of 11
(8,221 Views)
Forgot to mention I am running Win XP PRO
LV seem to be looking for the file  lvruntimeeng.msi
Alan
Message 2 of 11
(8,207 Views)
Hey Alan,
Sounds like one of your msi files have gone missing. A good ole fashioned "Repair Installation" should clean up this mess.
Logan H
Applications Engineer
Message 3 of 11
(8,176 Views)
Logan,
Thanks for getting back to me. Do I need to dig up my install disk, or is there some way to do this from inside the NI directory on my PC?
Alan
Message 4 of 11
(8,173 Views)
Logan,
I found my install disk and loaded it up. After asking for my SN, it proceeded to start to install ALL the files on my PC. I canceled the install because I wanted to REPAIR THIS UNSTALL as you suggested and this did not seem be about to do that.
Please advise.
Thanks!
Alan
Message 5 of 11
(8,162 Views)
Alan,
If things are missing on your install, it will try to install them. If you would like to get around using the CD, you can also download the LabVIEW Runtime Engine 7.0 on our website here:
http://joule.ni.com/nidu/cds/view/p/id/750/lang/en
Logan H
Message 6 of 11
(8,136 Views)
Logan,
Did not work at all. I tried downloading the file from your link, rebooting and I get the error that a more recent file is installed.   I did a complete reinstall  (not what I wanted to happen!!) by loading the set up disk at your suggestion. Lukily my files still seem to be intact. But It is still a PAIN to get passed all the promps to not load the runtime engine.... Help!!!!!
Any suggestions to try next?
Thanks....
Alan
Message 7 of 11
(8,125 Views)
Accepted by ajmartin
Alan,
The lvruntimeeng.msi that you said your program is looking usually resides in your drivers installer folder with a path like this:
C:\National Instruments Downloads\NI-DAQmx\<Your Version>\NIDAQ<Version>-1\Products\LabVIEW_Runtime_Engine_71\LV711RTE
Mine is exactly this path:
C:\National Instruments Downloads\NI-DAQmx\9.0.2\NIDAQ902-1\Products\LabVIEW_Runtime_Engine_71\LV711RTE
The 7.1 Runtime Engine is uniquely named "lvruntimeeng.msi". The 8.0 is named "lv80runtime.msi" and 8.2 is "lv82runtime.msi" and so on. Since we cannot install this 7.1 RTE because you have a more recent version installed, please check the path name described above to see if  your 7.1 Run-time Engine MSI is in there. Maybe even run a search to see if it is present anywhere on the system.
If not, we can uninstall and reinstall your DAQmx drivers and reinstall them since they will have each Run-time Engine MSI.
Clearly there has been a file structure mishap and these can typically only be remedied by completely reinstalling the program(s) that initially installed the file(s).
Logan H
Message 8 of 11
(8,117 Views)
Thanks, using the information you provided above I was able to solve the problem.
Thanks!
Alan Martin
Message 9 of 11
(8,101 Views)
hi, I want to install  LabVIEW Run-Time Engine 7.0.
I need some help
Message 10 of 11
(5,267 Views)
