LabView Real-Time under Broadcom AC131 10/100 Mbit
I would like to use Labview Real-Time on an Intel D201GLY MiniITX motherboard. Does anybody know that LabView RT the Lan Broadcom chip
AC131 supports? According: Requirements for a desktop PC as a real-time target, only the Broadcom ® BCM5751 chips runs under LVRT. Is there a
possibility to involve more drivers into the Rt- system, or someone knows a low cost ITX-Board for LabView RT?
Thank you
Marc
(5,027 Views)
This thread discusses ITX boards and it seems like one of the customers had found a board that works fine.
I found an ITX-board with a supported Ethernet adapter but as seen in the 'Requirements for a Desktop PC as a Real-Time Target' document there are more than the Ethernet adapter that needs to be fulfilled.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(4,916 Views)
