LabView IO Class Implementation Query
Hi All,
I have a problem with a correct implementation of IO control. The problem goes like this.
I have a user interface for a DUT which uses TCPIP, Serial and USB connection. On user interface, type of connection is selected from a drop down. which lets user input address of the DUT. This loads the appropriate class implementation for the module.
I am trying to avoid having three IO input controls on the interface, and ideally trying to avoid creating abstractions for the parent class to implement the required class.
I have tried type casting but there are mismatches at different parts of the code where some methods are expecting TCPIP instr. session as an input. I will need to use type casting in a lot of places and I am trying to avoid it.
"To a more specific class function does not work with IO VISA Class".
Is there a more cleaner way to programmatically select correct VISA class?
 Any help will be appreciated!
(2,508 Views)
Accepted by _T_M_
In few words...
IVI: Interchangeable Virtual Instrumentation. VISA isn't where you want to be.
"Should be" isn't "Is" -Jay
(2,499 Views)
Thank you for your help 🫨
(2,474 Views)
