LabView Embedded edition + Blackfin
Hello! My aim is to use LabView to generate applications and get C code as output, which I can alter before downloading to a Blackfin. It appears that the Blackfin Test addon, which I have on LabView 8, can only control Visual DSP++ and is not for developing applications; for one, I cannot see any special Blackfin Instrument Panel, as is claimed on the ADI website, where they use LabView embedded edition. Also, instrument drivers are not available for Blackfins, as such.
I want to know whether the full Blackfin instrument set is available for the standard LabView as well, or is it exclusively for the Embedded edition.
Thanks.
Kumar
(3,626 Views)
For now, the BlackFin module only works with the special LabVIEW 7.1 Embedded edition.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,612 Views)
Hi Kumar, You can find information about all of our embedded offerings, including DSP, the ADI Blackfin module and more here. It is true that you will require the Blackfin module for LabVIEW 7.1 Embedded Edition to target the Blackfin with LabVIEW-generated C code. The LabVIEW embedded module for ADI Blackfin does give you complete access to the generated C code in case you want to inspect it or tweak it to your liking.
Jarrod S.
(3,599 Views)
The frequency of sampling of the AD1871 analog-to-digital  and AD1854 digital-to-analog , is fixed or can I setting ?
(3,385 Views)
(3,383 Views)
