LabView Code
As part of a college project i have been asked to labview code a biaxial test rig that allows strains of different magnitudes to be applied in the x and y direction. I have all the other code just need this part
Can anyone help please ?
(4,296 Views)
I suggest you start here also there are a few links at the top of the main forum page under "LabVIEW Training Resources" with more training options.
Nobody it going to do your homework for you.
You are going to have to make a valid attempt at solving this first.
Then when you get stuck post some code and ask some questions.
=== Engineer Ambiguously ===
(4,264 Views)
This is not clear at all. What kind of "other code" do you have and what part of the problem is thus already solved? What is still missing?
Why did they ask you to do this?
(4,245 Views)
The biaxial test tig currently runs with the code that it there but the code needs to be modified in order to allow strains of different magnitudes to be applied in x and y direction. If you could gudie me how to do this that would be great!
(4,225 Views)
WE need to see the code you've already built. Please upload your VI, NOT PICTURES OF YOUR VI.
(4,219 Views)
Not without seeing your code.
(4,215 Views)
