LabView CANOpen Library ("CANopen SDO Write Object"), General error (COE_SDO_GENERAL, 134217728)
I've just started using labview2017 so if I'm missing something really obvious I apologise now!
I'm evaluating LV2017 with our application which is using LV8.5.1 - it used CANopen which wouldn't migrate as it seems all the CANOpen libraries are different!
I am using the NICANopenSW1700 download to add the CANOpen
with an evaluation version of LV2017 64bit
So to get myself going I opened the example and tried to compile / run but I just get bombarded with errors. It appears LV is trying to update the VI's and llbs but hasn't got permission - it is asking for a password to verify.
Am I missing something with LV?
Its the same if I use these vis/llb in my code too.
(4,930 Views)
Accepted by topic author Captain_Julz
Hi Julz,
So you want to replace this old CANopen library with a modern CANopen-library dedicated to special devices? (Comment: your NI8473 is NOT mentioned as supported by the modern CANopen lib!)
I don't think this will work (easily)…
You may try this:
- Install NI-CAN for LabVIEW2017
- Install that legacy CANopen library for LV2009
- copy the content of the LV2009 folder (all the stuff of the CANopen library) to your LV2017 folder
This way I can still use the legacy CANopen stuff with LabVIEW - last tested with LV2014!
Keep in mind: the old legacy stuff was only supported until LV2010…
I am using the NICANopenSW1700 download to add the CANOpen with an evaluation version of LV2017 64bit
Why do you use LV2017-64bit? Is there a special reason for?
Why not use the 32bit version?
(4,895 Views)
Hi GerdW,
Thanks again for your help.
I have installed the32bit version of LV2017 now,
Installed the NICAN1700
and copied over the CANOpen from my old LabVIEW directories.
My application successfully loaded and compiled.
I have quickly tested the NICAN interface and it works - I'll need to soak test this now to see if this has solved the original problem of loosing the CAN .
I don't have anything in at the moment to test the CANOpen properly but as soon as we do I'll try that.
I have been talking with Tomasz Dziendziel, from your Northern Europe sales team and he has suggested some avenues with new hardware that is fully compatible with LV2017.
(4,876 Views)
