LabView C# DLL Wrapper
Using LabVIEW 2017 (64-bit).  Wanting to use the DLL import wizard to wrap the attached DLL and header file for use in communicating with a BK Precision P/S.  The code fails on some of the function calls, particularly SI_Read, and SI_Write.  Problem seems to be the structure LPOVERLAPPED which LabVIEW reports is not defined in the .h file.
Would the 'proper' method be to modify the .h file with a typedef, or write the DLL calls manually and use null = o as a constant for the argument?
Thanks all,
Chris
(3,046 Views)
Accepted by bonnerupc
The latter! Configure this parameter as Numeric, Pointer Sized (Unsigned) Integer, Pass: Value and wire a 0 numeric constant to it. I'm sure this library has been wrapped about umtien times already in this forum and there must be even posts with attached VI library with the result!!
Rolf Kalbermatter  My Blog
(3,003 Views)
Thanks Rolf,
got it!
(2,990 Views)
