LabView, ActiveX, and Arrays
I'm experimenting around with using ActiveX controls in LabVIEW. I've
written a method in C++ that accepts an array as one of the parameters;
however, when I try to wire an array to that parameter in LabView, it
comes up as a bad wire.
Here is the .odl code:
[id(5), helpstring("method SetConfiguredIDs")] HRESULT
SetConfiguredIDs([in, size_is(ArraySize)] int* ID_Array, [in] int
ArraySize);
The prototype for the method is:
SetConfiguredIDs(int *ID_Array, int ArraySize)
I can wire an I32 control to the ID_Array parameter, but when I try to
wire an array of I32s, the wire is bad.
How do I specify that the input is an array?
Scott
Message 1 of 1
(2,856 Views)
