How to delete hidden Control on Front Panel
I have deleted the Attribute Node setting a control in a cluster to
invisible. So now I'm not able to delete this control on the Front
Panel. How to do this?
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,480 Views)
Gert,
Just right-click on the control's terminal and select ->show control. You
will then be able to delete the control as usual.
James
"Gert" wrote in message
news:8uto76$r8v$1@nnrp1.deja.com...
> Before you buy.
(4,480 Views)
Hi Gert,
perhaps the easiest way is to create a constant first from the cluster
control. When done you can create a control from this constant and your
control inside will be visible. Then you only have to delete the old one
and replace it with new created cluster.
good luck
Henrik
(4,480 Views)
There's an even easier way. Popup on the control in the block diagram
(it will never leave there), and click on Show control. That's it.
It's back on the front panel. You can now delete it normally
Before you buy.
(4,480 Views)
you have overreading following: "a control in a cluster" ....with the
normal show control entry it will not be visible!
Henrik
(4,480 Views)
If using LV6, popup on the cluster, go to the Advanced
menu, and near the bottom is a menu that will list all
hidden controls in the cluster allowing you to show them.
This is new to LV6. Previous version didn't have a way
to do this.
Greg McKaskle
(4,480 Views)
