LabView 8.5 and 2010 on the same XP machine?
Is it possible to install both version 8.5 and 2010 on XP machine? And then work on some of the projects in Labview 8.5 and on other projects in Labview 2010 without a conflict?
How about device drivers? Which version of DAQ driver will work in both versions of Labview?
Thanks much for any insite,
rita
(2,776 Views)
yes, it works. I am using 8.6 and 2010 on the same machine (and I think 8.5 is also installed...).
the only problem is that you need to be careful : a file saved in 2010 can not be open back in 8.6.. So, I am using almost exclusively now the 2010 version
hope this helps
(2,767 Views)
Accepted by rwinsoft
Always install older versions first. Some toolkits don't play well with multiple versions of LabVIEW. As for DAQ: http://digital.ni.com/public.nsf/allkb/F4E76EC05118F72D8625773000672298
(2,758 Views)
Very helpful!
thanks!
rita
(2,751 Views)
