LabView 8.0 built application won't install
I am having a problem with LV8.0 that I didn't have with previous versions.  I created an executable and an installer, specifying in the build specifications the additional installer: 'LabView Run Time Engine 8.0'.  The installer will not allow installation on another PC, and gives this message:  "You must install LabView 8.0 or later on the system before you can run this setup".  I manually installed the LV8.0 run time engine on the PC, and I still get this message.  I don't understand why the setup.exe will not allow installation.
(3,104 Views)
Did you check the box that says "Require Laview 8.0 or later" in the Installer Settings > Advanced Tab??  That may require you to have labview it self installed, not just the runtime.  I have not had the box checked in any installations I have created, and they all have installed without problems.
That was the only setting that I could find in the installer configuration that seemed to relate to your problem.  If you still cannot install after you check that, let me know and I can try some more things.
Kenny
Kenny
(3,090 Views)
Thanks ... that did it.
(3,083 Views)
