LabView 2011 Crashes After Long-term Run
I have a system that is running on LabView 2011 (11.0.1f2 32-bit), and it has crashed three times in the last two weeks whenever it ran for extended periods of time.
I have attached the dump file and am wondering if anyone can help me track down the source of the problem?
 4Strings
Message 1 of 8
(3,963 Views)
You have an access violation in there (0xC0000005), so it seems like you're indexing outside the program area or deleting some references. Cant see much more than that, but i'm no expert.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(3,942 Views)
Thanks! What exactly does that mean though?
Message 3 of 8
(3,939 Views)
It basically mean your program is trying to access memory it's not allowed to, typically other programs memory space or the OS's. One typical way this can happen is if a reference gets cleared, thus being 0 and you try to read/write from that address. Are you using .net components? Are you losing some reference?
/Y
Qestit Systems
Message 4 of 8
(3,934 Views)
As far as I can tell, the only things in the VI that are calling to something outside the VI are Write To Spreadsheet and SMTP Send Mail Message. I know for a fact the Send Mail Message hasn't been triggered during the runtime, but the write to spreadsheet logs data values to an .xls file continually.
-4S
Message 5 of 8
(3,929 Views)
Crashing after a long run could indicate a memory leak. If you monitor your memory usage in task manager do you see it steadily increasing over time ?
Message 6 of 8
(3,922 Views)
I'll have to check that. System is not at my current location...
Thanks!
Message 7 of 8
(3,920 Views)
If you're in a loop and are continually opening a reference without a corresponding close you could see this type of problem..
http://digital.ni.com/public.nsf/allkb/92DA0AC17D7DC09586256B36007E8B51
Message 8 of 8
(3,916 Views)
