LabView 2010 Robotics
The LabVIEW Robotics module includes an example project named "MobileRobots Interface Examples.lvproj", which should help you out.  You can find this by clicking "Find Robotics Examples" on the LabVIEW Robotics getting started window.
Message 21 of 23
(738 Views)
Yes,I know about that examples but I thought you have another examples.:)Another questions:I run the example Show map and drive Robot.vi, but when I select a
point where I what the robot went appear me an error: ArClientBase:Finding command for "gotoPose" but no data with that name exists ,and  ArClientBase: getCommand is 0 when it probably shoudn't be.I don't find the getCommand in the .vi.Can you help me with some advice?
Thank you!
Message 22 of 23
(736 Views)
Oh sorry, I failed to notice that you were the same person who posted about this earlier.
I don't have a robot to test with.  One suggestion would be to try the MobileRobots discussion forum...
http://robots.mobilerobots.com/wiki/Main_Page
They should be able to help you.  If you get stuck, contact me and I will try to find someone to help.
Message 23 of 23
(732 Views)
