LabView 2010 - CVI Driver Import Wizard
Hi Jesse,
the Import Shared Library function in LabView in LabView 2010 tells me, that it seems to be a CVI driver which I want to convert and recommends to use the CVI Driver Import Wizard 😉
I won't use the Import Shared Library function anyway, because the result does not look the same as with the wizard, so I installed LabView 2009 where I can use it.
Hope you will update the wizard for 2010 and 2011.
Greetings,
Thien
Message 11 of 11
(339 Views)
