LabVIEW webcam
I have posted a freeware library library that is capable of grabbing images from any USB webcam in Windows 98/2000/XP and displaying them on the front panel. A number of conversion tools are also included to convert the webcam images to and from the IMAQ format for image processing and display.
The library can be downloaded from http://www.mindofpete.org/ under the Ideas section and LabVIEW webcam library.
Pete
Message 1 of 13
(9,237 Views)
Pete,
This is a very nice toolset. If you are interested in developing more open source LabVIEW software, check out OpenG.org .
-Jim Kring
Message 2 of 13
(9,232 Views)
Thanks Jim. I'll definitely check out OpenG.org and post any other releases I make here when appropriate. I'm cleaning up a XHTML library that supports tag nesting and is compliant with the W3C standards. I'll post that on my site when it's done as well.
Pete
Message 3 of 13
(9,232 Views)
Pete,
I downloaded your webcam toolkit. it perfectly seems to be convenient for one of my projects but when I try to use it, it creates a fatal error at the level of the GRAB.
I'm using LV6.1 and WIN XP.
Could you tell me why it doesn't work correctly?
I have to make an avi file from a webcam.
Alexis de La Fontaine.
Message 4 of 13
(9,232 Views)
Hi Pete,
This seems to be a fantastic toolset. But LV crashes at the Grab vi. I am running LV6.1 on Win2000. Any suggestions.
Thanks in advance
Vipin
Message 5 of 13
(9,232 Views)
I had the same problem :
The solution is :
1) In Webcam initialize.vi : replace *4 by *8.
2) In webcam single capture : replace right value (in rect cluster) by 352 between "webcam snapshot.vi" and "webcam flat to picture.vi"
I'm using WINXP but i don't think it could change anything.
SECMAI
Message 6 of 13
(9,232 Views)
Hi Alexis,
thanks a lot... Ur suggestion fixed the problem.
Vipin
Message 7 of 13
(9,231 Views)
I cannot find it. Can you post please the exact link? it send me to http://www.dm.myway.com/ . how is it possible?
Greetings
Message 8 of 13
(8,152 Views)
Thanks for the post Pete, but I get the same error as PincoG when trying to go to that website.
Sounds like a great tool!
Jeff
Message 9 of 13
(8,145 Views)
Maybe i founded him. http://www.cs.unc.edu/~parente/index.shtml#About
Now i try. Greetings
Message 10 of 13
(8,137 Views)
