LabVIEW version change logs?
All,
Started with a new group at work and they are using a much later version of LabVIEW than I have been working with.  Is there a single reference page somewhere that lists version change logs?  I need to find out what changes/improvements/additions have been made between version 7.1 and version 2012 SP1.  I am sure quite a lot has been changed.
TIA,
Charlie
(3,093 Views)
Ummm...yeah.  A LOT has changed in that time.  Projects were introduced in 8.0.  Quick Drop in 8.6.  Scripting.  The File IO API had a major change somewhere in there.  Everything is now using DAQmx instead of the old Traditional NI-DAQ.  Object Oriented Programing in LabVIEW.  Project Templates.  Your Boolean constant is now half the size!
LabVIEW is still LabVIEW.  It still uses dataflow.  Therefore I seriously doubt you will have trouble adapting.  The best advice I can give you is to just play around with settings, palettes, and tools.
(3,073 Views)
Welcome to the latest version Charlie.
And here are the individual upgrade notes for each release (which should be more exhaustive)
LabVIEW 8
LabVIEW 8.2
LabVIEW 8.5
LabVIEW 8.6
LabVIEW 2009
LabVIEW 2010
LabVIEW 2011
The biggest change to your normal workflow will likely be the addition of the project. You have to use the project to create EXEs or target RT or FPGA devices. As far as I can remember that is the major forced change -- everything else is something you can ignore until you need it.
A few of my personal favorites that you now have access to:
LabVIEW Classes/OO
Diagram cleanup
Quick Drop
Good luck!
~Simon
(3,069 Views)
