LabVIEW simple pendulum simulation
Hi JT,
LV22Q3 isn't used so often as it may seem.
Could you please attach a downconverted version of your VI (File->Save for previous)?
(I prefer LV2019.)
Message 41 of 54
(3,148 Views)
Yes sure please try this file im attaching
Also these were the formulas i had to work with
Message 42 of 54
(3,144 Views)
Hi JT,
are you sure your formulas are correctly translated to LabVIEW?
Did you try to debug your VI using probes/highlighting?
Cleaning up the block diagram also helps to understand the code:
Why did you use the log2(x) function when your formula says to use the exp(x) function?
Message 43 of 54
(3,136 Views)
Im very new at this stuff but thank you so much for your help. When it comes to damping is my method correct ?
Message 44 of 54
(3,129 Views)
Hi JT,
when translating formulas into LabVIEW code it always help for clarity/documentation to use indicators with labels the same as your formula variables.
There is no "x" indicator in your VI, and there is no "t" indicator. (Instead there was an unlabeled control, which is a No-Go!)
And as already mentioned there was no exp(x) function in your VI: does that answer your question?
Message 45 of 54
(3,125 Views)
Kind of yes i have to label the equations, I just seem to be getting the pendulum to not swing how it normally does, as well as when it comes to applying damping, it doesnt seem to work, If possible could you look at the simulation on the VI and give me some sort of idea on how to fix it ?
Message 46 of 54
(3,129 Views)
Hi JT,
I already told you to debug your VI using probes and highlighting?
Did you?
Then you can easily spot the problematic parts in your code…
Message 47 of 54
(3,109 Views)
I wrote the code out that you cleaned up, and the pendulum isnt oscillating
Message 48 of 54
(3,055 Views)
Im very new to this so i dont know how to do the debug thing
Message 49 of 54
(3,053 Views)
I am attaching what I think is correct please do let me know what mistakes i have made if you are able to view it
Message 50 of 54
(3,038 Views)
