LABVIEW SERIAL MODBUS
I am attempting to read Modbus holding registers (10000 to 10150). While I can view the data successfully in a Modbus application, I keep encountering error 56 in LabVIEW.
Message 1 of 15
(3,216 Views)
Are you using both applications at the same time?
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 15
(3,177 Views)
Error 56 is a timeout error, so check your serial settings and your physical connections to the device.
Also make sure the Modbus application is not still open and has released the Com port.
=== Engineer Ambiguously ===
Message 3 of 15
(3,175 Views)
Double check the address numbers wouldn't you use address number 10000 ?
Message 4 of 15
(3,164 Views)
I have closed all the applications, but I am unsure if I am writing the address correctly. I'm not sure if the error is due to the address or something else.
Message 5 of 15
(3,162 Views)
I tried 10000 but still i got the same error
Message 6 of 15
(3,161 Views)
Have you tried serial type RTU?
Message 7 of 15
(3,154 Views)
have you tried without loop ?
Message 8 of 15
(3,120 Views)
Are these values in decimal or hexadecimal?
Message 9 of 15
(3,095 Views)
In decimal
Message 10 of 15
(3,064 Views)
