LabVIEW script
Dear All
I am Srikanth Vuppala, working on Gas separations using membranes. In my work I am using LabVIEW 2018, I need help regarding VI - if scripts available.
For pressure transducer (precision Fluid controls) 0 to 2.5 bar (down stream) and 0 to 40 bar (up stream) for these two pressure transducers I am using Pixsys ATR 142 sensors to record the data. For the acquisition of data in LabVIEW 2018 I need the VI script if available.
I request to you if someone has these VIs.
Thanks and Regards
(2,643 Views)
According to the manual for these pressure transducers, they can be controlled through a serial interface.  Any competent LabVIEW Developer should be able to program such an interface and develop a LabVIEW routine that would meet your specifications.  If your company already has a LabVIEW license, then they probably have (somewhere) LabVIEW developers who could handle this task for you.
(2,623 Views)
