LabVIEW programming for ARM Cortex R5
Is it possible to run a LabVIEW application on a ARM Cortex R5 MCU ? If possible, how to achieve this?
The MCU in this case is a TMS570LC4357 from Texas Instruments. It resides in a small development board - Hercules LAUNCHXL2-570LC43.
Many Thanks,
Paulo
(4,210 Views)
Nope.  NI only builds the LabVIEW compiler for targets they want, and as far as I know the ARM Cortex R5 is not one of them.  The closest you'll get is running LabVIEW code on a myRIO which is a ARM Cortex of some kind.  If you are looking for other cheap embedded solutions you can run LabVIEW code on a Raspberry Pi 3, or Beagle Bone Black with Linx.
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:3-0
(4,203 Views)
