LabVIEW program hang after starting
When i click run once/continuously, my program will cause my laptop to hang and had to force restart the pc.
(2,458 Views)
You must be doing something very wrong if you actually need to restart the laptop instead of just aborting run.
Could you save your VI for older version (2018 or 2019) please?
(2,453 Views)
I can't look at the code, but do you have some greedy loops? That can cause the computer to be very sluggish, but you should be able to use ctrl+alt+delete to get the task manager and abort it.
Qestit Systems
Certified-LabVIEW-Developer
(2,441 Views)
Accepted by topic author Ziheng
You have a while loop that is functionning at maximum velocity ==> meaning your computer CPU capacity.
You need to add a waiting time (even a small one) to minimize your CPU usage.
(2,440 Views)
thank you! my problem is solved after implementing a Wait
(2,437 Views)
So it was a Greedy loop? Good guess from me. 🙂
Qestit Systems
(2,425 Views)
