LabVIEW load error code 3: Could not load front panel
Yes, but I'm not sure if I did use the right ini file, because at this PC there are two versions of labview 2011, the German and the English one
Message 51 of 176
(3,545 Views)
you find the LabVIEW.ini file in
\Program Files\National Instruments\LabVIEW 2011
Do you mean, two installations of LabVIEW same version but in different languages ?
It is not recommended/possible to install LabVIEW in the same version in different languages.
Message 52 of 176
(3,542 Views)
the German version was installed but didn't work correctly. we uninstall the German one and install the English version. however there are two LV 2011 folders.
Message 53 of 176
(3,534 Views)
you can install LabVIEW in different languages but not same version, so if you install LabVIEW 2011 in English and LabVIEW 2010 in German, you will find  two folder LabVIEW 2011 and LabVIEW 2010 in
Message 54 of 176
(3,530 Views)
thank you very much for you help RMathews.
Message 55 of 176
(3,515 Views)
I'm getting the same error code using LabVIEW2011, and changing the .ini file did not work.
I was adding a terminal to the SubVI and the icon did not update or save, then I got the error message and could not open the SubVI anymore. I have attached the correpted VI. @RMathews
 can you please tell me how to fix the VI myself in case it happens again?
Thank you very much!
Sincerely,
Xinru
Message 56 of 176
(3,474 Views)
HI Xinru,
here you have the VI.
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 57 of 176
(3,463 Views)
Hi RMathews,
Thank you so much!!!
Message 58 of 176
(3,435 Views)
Im also getting the same problem
Message 59 of 176
(3,425 Views)
I'm having the same problems. I've installed SP1 and altered the init file. Could someone fix this file? It would be greatly appreciated.
Message 60 of 176
(3,375 Views)
