LabVIEW load error code 3: Could not load front panel
You can download the LabVIEW Evaluation software (2011 or higher) and try it yourself, or you contact your local NI office. They can maybe help you. But if you used 2011 SP1 and it didn't work, it is quite unlikly that somebody else can help you.
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 111 of 176
(2,508 Views)
thanks a lot,i will try it,
Message 112 of 176
(2,506 Views)
Hi RMathews,
I'm using the LabVIEW 2009 evolution.
When I open my vi, I have the same message:
LabVIEW load error code 3: Could not load front panel.
Can u repair attached file for me, please?
Tks a lot!
Message 113 of 176
(2,455 Views)
It opened okay for me in LV 2012, so I back saved it for 2009.
Be sure to give all controls a name.  You can hide the labels on the front panel if  you want.
There is an extreme use of local variables in there that should be cleaned up.
Message 114 of 176
(2,439 Views)
Thanks a lot!
That is a highly experience for me.
Message 115 of 176
(2,429 Views)
Hi all!
I have the same Problem like everyone... But the error only occurs when I execute my exe file. In developpement mode can I open and modifie my VI.
Can someone help me?
Best regards.
Meilleures salutations.
LV2012
Message 116 of 176
(2,366 Views)
please check this document. It should solve your problem.
Cheers, RMathews
Ramona Lombardo
Message 117 of 176
(2,358 Views)
Hello, I have the same problem I can't open a VI it says "Could not load front panel". I tried to fix it by adding  parameter connPaneRecoveryMode=True in Labview.ini but didn't work.
I'm using Labview 2011 but I don't have access to download SP1. I really would appreciatte if anybody can fix my VI for me. I really don´t need front Panel I just want to recover the code.
Thank you in advance.
Message 118 of 176
(2,164 Views)
Hi Lenin,
here you have the VI.
Ciao, RMathews
Ramona Lombardo
Message 119 of 176
(2,130 Views)
Thank you very much RMathews you just saved my work !
Message 120 of 176
(2,112 Views)
