LabVIEW is crashing when i am trying to build the exe
I am trying to build an executable from a program in which i am communicating with several instruments, whenever i am trying to build an exe labview is crashing and i am getting the error Exception: access violation(0xc0000005)at eip=0x10054DD1.
after reading some posts on forum i tried builduing an exe on other system also, but still i am getting the same error.
below i am attaching the program and the image of the error i am getting.
(2,537 Views)
waiting for the reply....
(2,504 Views)
Realize this community is by a large majority volunteer based.  If you need urgent support contact NI directly
http://sine.ni.com/apps/utf8/nicc.call_me?loc=en-US
That being said I would try to disable the large amount of code.  Say you have a Main that launches a bunch of stuff, put a disabled diagram code around the launching part and then try to rebuild.  It is a very slow process (especially when the build takes a while to fail) but by doing this you can more isolate the parts of the code that can cause the crash.  The only time I've seen a crash on build like you described, I simply rebooted and it was fine.  Usually because of my own fault by stopping code in a bad way previously leaving things in memory.
(2,491 Views)
