LabVIEW hang in Serial communication !!
hi.
I use pl2303HXA (usb to UART converter) in my design and send data from micro to pc in LabVIEW 2013 x86.
when i tried in CODEVISION terminal, every thing is OK and each micro send to PC, in Hypertermial or CODEVISION terminal is correctly received.
but when I run LabVIEW, it work few second and Communication suddenly abrupt and LabVIEW has hang. u can see that in below image that I capture from my decktop. Why LabVIEW hang ?
image is front panel of my VI.
whenever it hang, I must restart LabVIEW and test again. in meanwhile I must said that hang is randomly occur.
Thanks.
Message 1 of 28
(5,461 Views)
Where's the block diagram? Can't tell a thing from just the front panel.
Message 2 of 28
(5,449 Views)
What kind of baud rate is that?
Bill
CLD
(Mid-Level minion.)
Message 3 of 28
(5,444 Views)
baudrate is ok. I changed it to 115200 but LabVIEW hang again !!
This is image from my Control panel.
Sub VI in above image get a 24 bit 2's Complement hex string and it's output is DBL number which can be positive or negative. Sub VI is shown below :
Sub VI work correct and in my opinion problem is not from that.
my OS is Win7 x86 and LabVIEW is 2013 x86.
VISA is installed full and correct.
I send Data with little delay approximatlly less than 0.5ms. Communication is Right in Other terminals like Hyperterminal but in LabVIEW work few second and suddnly hang and I must restart LabVIEW and Micro to continue.
Data Sendig from Micro is continusly and Idle time isn't exist.
Message 4 of 28
(5,431 Views)
I don't see a Write.
Message 5 of 28
(5,424 Views)
Is your communication really using a Termination Character? You did not deactivate it on the serial configuration VI.
Regards, Jens
Kudos are welcome...
Message 6 of 28
(5,411 Views)
The hang isn't "random".  It's telling you that you don't understand how to communicate with the equipment.  I see you are using bytes at port AND using a termination character (on by default in the serial config).  Use one or the other, but not both.
Bill
CLD
(Mid-Level minion.)
Message 7 of 28
(5,408 Views)
First of all I must appreciate your's reply 😉
as you said I deactivate termination character and run my VI again.
it's run correctly longer than previous mode but yet has same problem and hang again !!
it's new image from my VI :
as you see above, problem which was hang in receive still is !! Smiley Frustrated
Message 8 of 28
(5,383 Views)
Please connect an error out indicator. Also, what is special about 6 bytes? You have absolutely no synchronization so it would seem that the bytes are just random. It would be better to append a termination character with the micro code and enable it on LabVIEW.
Message 9 of 28
(5,371 Views)
How I can connect  an error out indicator to my VI ?
6 is not my hero number Smiley Tongue   ,  in micro I send 6 byte every time to PC and I set this point in byte as port .
your offer is I append a byte to my Protocol and send 7 byte in every Communication with a termination character like 'A' in end of my Protocol ?
Message 10 of 28
(5,364 Views)
