LabVIEW edition
Background is that I've always run Base LabVIEW for PC applications only. Now I'm looking to use CompactRIO for more reliability and better control.
Is LabVIEW Professional Edition required to deploy programs to CompactRIO target? I can't get a response from NI. I'm confused since you can still run RT module with the Full edition. But unless you can deploy your program on the cRIO target, then of what value would the RT module be?
(1,485 Views)
Accepted by d_vinson
According to here, you can deploy to a cRIO with the RT and/or the FPGA modules if you have the Full edition.
(1,470 Views)
Thanks.. I must have overlooked that when going through the table earlier. Appreciate your help.
(1,456 Views)
