LabVIEW development environment not working properly
I have the exact same problem. However I want to add, that the hang time of labVIEW after the first right click is directly  related to the project size that is open (for me at least) Are there any news about this topic? I use LabVIEW 2017 SP1 32 Bit on Windows 10. The Hang time is up to 30 minutes which is obviously unbearable.
Not sure if related, but if I click CTRL+SHIFT+Run to recompile all VIs in memory (I know its not advised, but solves a build issue we have). The Dev System acts exactly like with the right click and for the same amount of time. Is it possible that LabVIEW Decides for whatever reason that a recompile might be necessary?
former NI TSE, now LabVIEW Architect
Message 11 of 12
(424 Views)
Do you have the option to separate the compiled code from source code enabled in your project?  (And even better, in your options?)  This would keep the need to recompile to a bare minimum, and it might even solve your build issue.  Be advised that if you didn't and then you enable it, there is one more step to complete before it is actually enabled for existing code.
Bill
CLD
(Mid-Level minion.)
Message 12 of 12
(411 Views)
