LabVIEW crashes when programmatically getting the dependencies from a large project
Hi all,
I am working on a LV application in which a project has to be created programmatically & its dependencies have to be analyzed. But when I add a source folder containing large number of files (>1000) LV crashes when getting the Dependencies reference (in the highlighted method in the image below). Is there a workaround for this issue? Also finally I will have to compile this entire code to Packed Project Library. Does it require any extra coding?
Priyadarsini S
(3,547 Views)
Accepted by Priyadarsini
Do you save the new project before you try to read the dependencies?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,540 Views)
Hi Mike,
Saving a project before and after getting the dependencies solved the problem. I remember doing it earlier, but after your suggestion tried again and it did work great. Many thanks!
Priyadarsini S
(3,500 Views)
