LabVIEW crashes when looking for errors
When I have a "broken arrow" error. LabVIEW crashes when I try yo search on the errors. Also, It crashes when I try to build the system.
(3,128 Views)
Marjeb:
There is no reasons why LabVIEW should crash. Please complete the following steps to generate an error log  file:
1. Go to Tools >> Options in LabVIEW and under the Debugging section, select Prompt to investigate internal errors on startup.
2. The log file created after internal LabVIEW errors is called LabVIEW_version_username_cur.txt and it is stored in your temporary directory. By default, this directory is located at C:\Documents and Settings\(User Name)\Local Settings\Temp (Windows 2000 and XP).
I hope this helps and please let me know what you find.
Rudi N.
(3,119 Views)
I tried that - I even gone through every little warning and fixed them. All I have to do is delete a wire anywhere, in order to force an error and when I try to find the error, LabVIEW crashes. The log file tells me nothing.
Tom
(3,099 Views)
Tom:
I am sorry you are experiencing such issues with LabVIEW. It would greatly help me if you could post the error log file.
Rudi N.
(3,087 Views)
