LabVIEW crash
when  I run my program,the labVIEW will crash and when i open the software again ,happen a dialog" A recent run software, internal warning 0x05751666appeared in compiler.cpp"and the vi will not open again
thank you very much.
(4,900 Views)
  1. Please next time do not attach such huge (over 4MB) picture, takes long time to load. Also, are you aware that in Windows you can take a screenshot (http://www.wikihow.com/Take-a-Screenshot-in-Microsoft-Windows) ? 🙂 You do not need to make a photo with your smart phone 🙂
  2. You should attach your VI which crashes LV so people can have a look at it...
(4,848 Views)
Blokk 已写:
hi,Blokk
thank you very much for your help.My program is TDK-Lambda Z+driver Program,download from the NI  website, And based on this modification.Every time I found the program from the 'instr. Lib' folder under loading.When I put the original driver in the 'instr.lib'and let the modlified program in the U disk,my program can display,Each change will be stored in local disk folder'instr.lib'. when  I at another computer open the program,found program no change.
1. I doubt whether is because the cause of the driver
2.How modfied on the basis of the driver program , and can be stored in a removable disk .ensure can open normal at another computer.
(4,802 Views)
  1. You did not attach your vi, just a picture. Attach your vi itself.
  2. Give a link of the above mentioned driver.
(4,792 Views)
Blokk 已写:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=F00572BCE06A6F91E0440021287E6A...
LabVIEW2014
(4,787 Views)
@杨震 wrote:
Blokk 已写:
hi,Blokk
Sorry, it is still not really clear what is your problem. You talk about different drives and computers. You originally talked about LabVIEW crashes. Could you try to explain more clear what is going on?
And you still did NOT attach your actual VI. Is it an example from the driver itself, or you modified it? Is the power supply connected to the PC when the crash happens?
If you place an instrument driver in the instr.lib folder, you should not change/modify/delete the original VIs! Create your own VIs at another folder on your hard drive, based on the driver VIs. This will ensure that when you move your OWN project to another PC also having the same instrument driver in the "instr.lib" folder, will work.
In case you do not need further changes of your application on the other PC, another option is that you create an executable (requires drivers and run time engine (RTE) at the target PC) or a stand alone installer packing up all necessery components (RTE, VISA driver, etc...).
(4,784 Views)
