Incorrect Resource Class
I am using an Agilent E3647A power supply. I had it working perfectly well however I had an issue and tried to fix this by uninstalling and reinstalling the driver. The issue turned out not to have anyting to do with this. When I tried to reinstall the driver it seems to think the correct resource class is RAW when I know it to be INSTR from using it on another computer. I have tried uninstalling the driver agian but had no luck.
Any help would be appreciated.
(3,801 Views)
You can change the resource name in the code as same as its gets detected in MAX/ Device manager of your system and make the Resource name as configurable for future use without code changes
(3,755 Views)
