08-23-2022 06:07 AM
I am trying to setup a standalone CI server to automatically run unit tests written in Caraya. The ultimate goal is for it to also run VI Analyser on changed files and build an executable/RT build on commits made to the trunk.
My current setup is:
I am struggling to get it work reliably though and am looking for advice for any changes I could make to my setup.
The recurring issues I am getting are:
E:\.jenkins\workspace\_redacted>"C:\Program Files\G-CLI\g-cli.exe" --lv-ver 2019 "C:\Program Files (x86)\National Instruments\LabVIEW 2019\vi.lib\addons\_JKI Toolkits\Caraya\CarayaCLIExecutionEngine.vi" -- -s "E:\.jenkins\workspace\_redacted" -x "E:\.jenkins\workspace\_redacted\report.xml" LabVIEW terminated unexpectedly! Read Error : Read Length: Exception Found System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.EndReceive(IAsyncResult asyncResult) at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at G_CLI.lvComms.<readMessage>d__15.MoveNext() Since the network stream will be out of sync the application will now exit.
E:\.jenkins\workspace\ches_valve_fault_allowable_limit>"C:\Program Files\G-CLI\g-cli.exe" --lv-ver 2019 "C:\Program Files (x86)\National Instruments\LabVIEW 2019\vi.lib\addons\_JKI Toolkits\Caraya\CarayaCLIExecutionEngine.vi" -- -s "E:\.jenkins\workspace\ches_valve_fault_allowable_limit" -x "E:\.jenkins\workspace\ches_valve_fault_allowable_limit\report.xml"
Connection to LabVIEW timed out!
LabVIEW exited with code -1
09-02-2022 09:47 AM
Hi Niatross,
I suggest you to go through this link Caraya Unit Tester - VIPM Community and see if you can find anything useful there.
