07-25-2007 09:42 AM
07-26-2007 09:54 AM
Hi David,
Could you attach the example?
AdamB
07-26-2007 11:26 AM
I'm not sure I completely followed your use case, but I can tell you that a VI in an LVClass with dynamic dispatch inputs cannot be used in a polymorphic VI. This is a known limitation.
If this is not what you are asking, as Adam suggested, attaching the VIs that you referenced would be helpful. 🙂
Thanks!
07-27-2007 04:49 AM - edited 07-27-2007 04:49 AM
Hi Jeff,
Just came on here to post a bit of code for Adam to have a look at, but having read your answer there's probably no point - if it's a known limitation then there isn't anything that can be done about it - any idea if this will be fixed in a future LabVIEW version as polymorphicism is a fairly fundamental part of OO programming?
Message Edited by davidpcl on 07-27-2007 04:51 AM
07-27-2007 07:29 PM - edited 07-27-2007 07:29 PM
Message Edited by Jeff B on 07-27-2007 07:29 PM
07-30-2007 05:38 AM
