I use LabVIEW built-in VIs to save a big 2-D array data into a ascii file (with the "write character to file" vi). When I write it on the local hard drive, it takes about 5 seconds to complete the task. But when I write the file on the network, it takes more than 5 minutes. A typical output file is 5MB big.
If I write the file on the hard drive, and use the built-in File MOVE vi, it takes about 30 seconds to complete the MOVE operation. But if I use Windows File Explorer to move the same file, it takes less than 1 second.
Both the PC and server are connected on a full-duplex 100BaseT network. I tried different file I/O operations (including MOVE, create new file and LIST)
with LabVIEW VIs and compared the speed with windows file explorer. It turned out LabVIEW VIs performance is always A LOT slower than Windows File Explorer. I tried the same test on many different PCs, with windows 98, NT, 2000, and the results are the same.
Is there anyway to improve the file IO performance or is there any other workaround on this issue, such as calling Windows File Explorer to perform the same task via ActiveX maybe?
Your imputs will be very much appreciated. Thanks!
Dan
