LabVIEW application targeting DSP
hello!!
i m working on c6713.for thiz i have installed code composer studio 3.1 and at the same time i m using matlab7.5.bt i want to work on lab view.but i m new to lab view enviroment.i need to know which version of labview does support c6713?
and moreover do i need ccs3.1 if i use lab view?
Message 11 of 18
(1,935 Views)
hello!!
Message 12 of 18
(1,935 Views)
I believe you will need LabVIEW and the Digital Signal Processing Module version 8.2 or higher.
Chris Bakker
SET Americas
CEO
Message 13 of 18
(1,921 Views)
hello!!
how to use labview with dsp?coz i m using matlab with tms320c6713 dsk board.bt i m having compatibility problem.so can any body tell me?
Message 14 of 18
(1,913 Views)
Here are some links you may find helpful.
[broken links removed; articles no longer available]
Chris Bakker
SET Americas
CEO
Message 15 of 18
(1,902 Views)
I'm also finding difficulties in using DSP C6713 with LabView
I'm not sure what extra drivers are necessary if I dont need CCS, how is the PC supposed to recognize the DSK?
Message 16 of 18
(1,840 Views)
New thread here
Message 17 of 18
(1,835 Views)
Hi Justin,
I came across this thread while trying to look for some help regarding "build specifications" and building a stand alone app using LabView. I am working with a DSK6416 and im trying to build a simple function generator as well as an arbitrary waveform generator. I thought a smart way of doing this would be to develop several little VI's (1 for sine wave, 1 for square wave, etc.) - then build these as .exe files and call them from a simple user interface built in VB.Net or something similar. However, after several attempts, it seems these executable cant be build - if I try right click on build specs under My Computer, and then goto the Source Files section, as expected the are no available VI's as they exist under the DSK6416 section.
Is there any way around this or any better way to do what I'm trying to? I want a VB GUI as for the AWG section I want the user to enter the desired waveform in equation form...
Any help is much appreciated!
Thanks.
Message 18 of 18
(1,788 Views)
