Hallo,
here one small question.
LabVIEW application running under Windows2000.
Now Ctrl+Alt+Delete pressed, then "Log Off..." choosed.
LabVIEW application closed, but Windows don't logging of and Ctrl+Alt+Del must be pressed again for logging of. The same situation with "Shut Down...".
If two application are running, then only one received AppExit event, and second - not.
How can I avoid this situation?
My goal is following: by Ctrl+Alt+Del->LogOff/ShutDown all LabVIEW application must be closed. Do you have any _simple_ solution?
Thank you.
Some examples in attachment. Just start these application, then try to logging of or shutdown.
