customize file output
Say I want to create a custom template for exporting data from LabVIEW.  Currently I am using DAQmx and using the write to measurement file vi.  This is not allowing me to customize what goes in each column and so forth.  Is there an easier way for me to achieve this.  I need a custom format so that I can scope / analyze the results later.  I have also tried creating a string without success
Message Edited by HereWeGo on 08-11-2008 12:44 PM
(2,857 Views)
Hi HereWeGo,
try the "Write to Spreadsheet File" function. You can create your own array and write it to a file.
Hope it helps.
Mike
(2,851 Views)
Thanks Mike,I'm new to this software. Is there a way to insert heading information and a column for time using this spreadsheet vi?  I currently have my data output wired to the 2D data input
(2,843 Views)
Hi HereWeGo,
you can use the array functions to build what you need.
Mike
Message Edited by MikeS81 on 08-11-2008 08:21 PM
(2,835 Views)
Hi HereWeGo,
An Applications Engineer at NI created an example to insert information into a spreadsheet file with header information which is posted on this discussion forum.
Hope this helps!
Warm regards,
Karunya R
(2,807 Views)
