LabVIEW and Sentinel Protection Installer clashes?
Greetings everyone,
   I just installed LabVIEW 2012 on a backup XP machine (XP Pro, SP3, 32 bit). No problems except that, on startup of the machine, I receive a spnsrvnt.exe error and that it needs to close, and that process is associated with Sentinel Protection Installer.
   The only thing I could find on the boards about it is here: http://forums.ni.com/t5/LabVIEW/error-with-spnsrvnt-exe-at-startup/td-p/386705
    Any ideas on this one?
    Thanks!
    TheLT
(4,738 Views)
Accepted by topic author TheLT
TheLT
This is most likely a port conflict issue.  I think you'll find this useful.  If you're receiving a different error, please include a screenshot.
(4,711 Views)
Thanks Kyle! That did the trick!
VV5
(4,703 Views)
the link (under "this") is not available any more. Could you explain what to do if I want to install the Sentinel Protection Installer while I have LabView 2018 installed?
Thank you
BR Eugen Wiebe
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(2,291 Views)
Also possible to modify Logos Ports:
HKLM\Software\National Instruments\Logos\Ports
HKLM\Software\Wow6432Node\National Instruments\Logos\Ports
(be aware that 64-bit Windows maintains separate entries for 64-bit and 32-bit processes)
In Ports:
FirstClientPort REG_DWORD 7000 (dez)
FirstServerPort REG_DWORD 8000 (dez)
This was useful for me because I wanted to install Sentinel Protection Installer and could not because of this problem.
After modifying in registry and restart, it worked!
Eugen Wiebe
Bernstein AG
(2,271 Views)
