LabVIEW Timed Loop
how can I configure a timed loop to execute upon entry, rather than waiting for the first delta time?
If my delta time is 10 seconds, I get my first execution after 10 seconds. I would like to execute the loop when it is initially entered (second 0) then wait every 10 seconds after that.
Thanks.
Message 1 of 9
(5,678 Views)
I don't think you want to use a Timed Loop here.
Timed Loops are meant mainly for RealTime systems which need to be deterministic on relatively short timescales.
For a 10 second wait, you should be using a normal loop with a 10 second wait inside of the the loop.
Message 2 of 9
(5,662 Views)
What are you seeing that makes you think things are executed after the loop is done instead of immediatley?  Can you let us see your problem code?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 3 of 9
(5,661 Views)
Thanks, but you're missing the point. The 10 second timing is to demonstrate the problem I'm trying to solve.
Message 4 of 9
(5,635 Views)
Here is a very simple example. You will notice that the initial increment of the iteration counter occurs after a 5 second wait, which is the delta time. I would like this to execute immediately then every 5 seconds thereafter. (Sorry for changing the 10 seconds to 5, but wanted a shorter time)
Message 5 of 9
(5,631 Views)
Accepted by topic author rls9642
The first iteration of a loop, any loop, is iteration 0.  That will not change to iteration 1 until the next iteration has started.  This is expected behavior.  Anything inside the loop will execute immediately but the iteration counter won't increment until the next iteration starts.
Kelly Bersch
Message 6 of 9
(5,624 Views)
Set your iteration count to -1 before running.  Then you will see that the iteration goes to 0 for the first iteration (yes, i is 0 based) quite quickly.
Message 7 of 9
(5,613 Views)
copy the code inside the timed loop and put the copy outside of the loop.  This way, the code will execute once before entering the timed loop.
Message 8 of 9
(5,603 Views)
Having redundant code accomplishes nothing.  The code will already execute immediately on each iteration of the loop.
Kelly Bersch
Message 9 of 9
(5,596 Views)
