LabVIEW Signal R Hub Connection
is it possible to connect to a Signal R Hub using LabVIEW?
It is not possible to add .Net Dlls as wrapper because LabVIEW still does not support .Net (Core) Dlls...
Is there any other way?
(1,838 Views)
The protocol is published here. You can write your own client. The .net and JavaScript clients are in the open source signalr repo on GitHub. You can use them for reference.
(1,731 Views)
