LabVIEW SQL 'Declare' Variable
I have scoured the internet searching for an answer to this, but no luck...
I am attempting to write to a MS SQL database from LabVIEW.
The query is:
DECLARE @k INTEGER
SELECT @k = MAX(Component_ID) FROM Subassembly_Info
UPDATE Subassembly_Info
SET Rework = 'True'
WHERE Component_ID = @k
In this example, Component_ID is my primary key from the table Subassembly_Info, and Rework is a bit (boolean) column
The query works just fine in SQL Server Management Studio, but I get this error when I run it using LabVIEW:
Error -2147217900 occurred at NI_Database_API.lvlib:Conn Execute.vi->Write_SN_To_DB.vi
Possible reason(s):
ADO Error: 0x80040E14
Exception occured in Microsoft SQL Server Native Client 11.0: Incorrect syntax near '@k'. in NI_Database_API.lvlib:Conn Execute.vi->Write_SN_To_DB.vi
What I am trying to do is write data to the last row that already exists in the table (i.e., not append a new row). I am doing this because I am going to be writing ~90 sets of measurements to the table (each measurement gets a column), and I would like to do this in a loop structure.
Any help would be much appreciated...
(4,190 Views)
Accepted by SandraY
Look into using the clause "output inserted.id" on your initial insert statement to get the primary ID.  For example,
INSERT INTO my_table
column_name_1,
column_name_2
output inserted.id
VALUES
'value1',
'value2'
You could also look at putting your code in a Stored Procedure and calling it from LabVIEW.  That is what I normally do.
(4,177 Views)
I don't think named parameters are supported.  Look into the Create Parameterized Query VI.
aputman
(4,163 Views)
Try this:
UPDATE Subassembly_Info SET Rework = 'True'
WHERE Component_ID = (SELECT MAX(Component_ID) FROM Subassembly-Info)
(4,159 Views)
Thank you!
I am attaching my VI that returns the index of what I've last written to. It is kind of a mess, but Case 1 illustrates the solution.
(4,154 Views)
