LabVIEW - SOLIDWORKS SoftMotion (Error -77080)
Hi, I'm stucked in my project since this error started appearing. I've searched a lot in Internet but I haven't found a solution yet. It would be much appreciated if you can help me, thanks.
PD: It happens with my project and also with default examples. I've tried disabling/enabling SolidWorks Motion Module, deploying motors in separate, opening SolidWorks and then Labview and vice versa.
Message 1 of 8
(5,553 Views)
I'm still stucked. I tried opening SolidWorks from LabVIEW but popup window is still appearing.
Message 2 of 8
(5,390 Views)
I hope you are doing fine. I did some research about your issue and it seems to be common. I believe checking this  older forum could worth the try:
Discusiones-sobre-Productos-NI/error-77080-An-error-ocurred-while-reading-deploying-data/m-p/3149989
I will also recommend verifying if you are following the steps from this tutorial:
http://www.ni.com/tutorial/9566/en/
Randy @Rscd27@
Message 3 of 8
(5,374 Views)
Thanks for your answer. I've already read that link and a lot of others, I haven't found a solution yet. Help.
Message 4 of 8
(5,352 Views)
I believe maybe using this example could work:
http://forums.ni.com/t5/Discusiones-sobre-Productos-NI/error-77080-An-error-ocurred-while-reading-de...
Randy @Rscd27@
Message 5 of 8
(5,288 Views)
It's weird. I opened the project mentioned in that link, I ran it, closed it, opened my project and now it works. Thanks for your help. Smiley Very Happy
Message 6 of 8
(5,256 Views)
I am really glad that it worked. Remember to mark my answer as correct :)!!!
Randy @Rscd27@
Message 7 of 8
(5,222 Views)
MUCHAS GRACIAS. PUDE SOLUCIONAR EL ERROR GRACIAS A ESTA RESPUESTA
Message 8 of 8
(4,437 Views)
