LabVIEW Runtime 7.0 Linux and Mozilla
I have successfuly instaled runtime plugin into Mozilla under linux. I copied plugin into mozilla plugins directory.
When I connect to any page with LV Remote Panel, the plugin loads the page, but after 100% it doesn't work. It just display gray rectangle, or the Remote Panel on incorect position. Does somebody has the same problem? Do you have any working example of Remote Panel web page which I can use for testing?
Ondra
(3,206 Views)
Hello Ondra,
Thank you for contacting National Instruments.
What version of LabVIEW are you running? To use the Run Time Engine (RTE) 7.0, you must be running LabVIEW 7.0.
If you are running 6.1 or earlier, you must install the corresponding RTE. To view LabVIEW 6.1 front panels in Mozilla, further steps will be necessary. Please follow the link below for instructions.
http://digital.ni.com/public.nsf/websearch/93D8AD6F55D6F91486256BE6006FB868?OpenDocument
Let me know if this does not solve your problem.
Sean C.
Applications Engineer
(3,206 Views)
Hello Sean,
I'm running LabVIEW 7 Express and the Front Panel works OK on Windows XP with Internet Explorer and RTE 7.0 for Windows.
The problem appears only in LINUX. There is no other RTE for LINUX which I can try. Maybe the problems is with my distribution, or mozilla version ...
Could you send me your e-mail address?
I would like to send you www address with embedded Remote Panel which is not working for me.
My mozilla is version 1.4 and I have Mandrake 9.1.
Thanks Ondra
(3,206 Views)
Hello Ondra,
After some research I have discovered that Mozilla is not supported for viewing remote panels. I suggest using Netscape 6 or later.
I hope this helps,
Sean C.
(3,206 Views)
